S&S Easy Start Cams
  • DocWilson
    DocWilson
    Hi all just fitted a set of Easy start cams to my 09 FLHRC and I am very impressed . The bike no longer hesitates on the starter and the dreaded clunk has gone .Did the first run up to the Burdekin Bike show last weekend and the improvement in torque is awesome .At the show everyone wanted to hear it start so I started it about 10 times and the battery didn't even sound tired . the best it would do when standard was only about 3/4 starts before the battery started failing .
    I haven't got the tune fully sorted yet as it has a bit of a flat spot right on cruising speed witch is a pain but I'm putting it back on the Dino next week to sort that. so far we have 104 ft/ib and 87 hp .
    09 road king classic 103 with stage 1 ac true duels se slip ons 551 easy start cams se pro tuner
  • DocWilson
    DocWilson
    dave is at Ayr Burdakin Motorcycles He does a lot of racing with sprint cars and the like  so hes pretty switched on
  • DocWilson
    DocWilson
    Hi Guys
    Just a quick update . I took the bike back down to the Burdakin last week and we had a play with the timming this time and it has made a huge difference . When Dave loaded the SE map into it He only changed the fuel settings and didnt touch the timing but it took6 deg + over the whole range and another 4 deg at 1850 to 2500 where the flat spot was bad but even at that I can lug it down real low and it wont ping which tells me it can probably take some more advance yet.So that map must have been way out .
    Its going heaps better and Im doing a run up to Cairns next week and we will see what the fuel consumption is like.
    I think we r getting real close now and Dave has been great I would recomend him to any one who wants a dino done.
