Could they have made it any harder
  • the_mongrel
    the_mongrel
     So today I decided to get started on the oil change. All three holes.
    Started with the tranny. Talk about a pain the arse. The drainage plug is in such a bastard of a spot between the shocks. :(
    as if that was not bad enough, the filler plug is also a bitch to get at. Fuck me!!!
    I can only hope the other two are easier to get at.
  • the_mongrel
    the_mongrel
    Am I missing something???
  • the_mongrel
    the_mongrel
    Thanks mate. I got the drain plug back in ok. New o-ring and it went in without issue. Getting the oil in was fun. Redline is thick shit and with the filler under the oil tank, I could not just pour. Had to use a funnel - slow, but it went in.
    I just think that being that oils are to be changed at regular interval, they could have spent some time to make it a bit easier.
    Ann well. The first one is done now. 2 to go tomorrow.
