Online: Ronmac
Flush Fitting fuel gauge/ fuel cap
  • rockyrob
    rockyrob
    Hi , Has anyone fitted the HD flush fitting guage/fuel cap to a carbed 01 Fatty. The parts list doesnt include 2001 but only 2004carbed
    62818-06E
    Chrome
    Fits '04-'06 carbureted and '01-'07 fuel injected Softail® models (except FXSTD/I).
    But i understand (most likely wrong) that an 2004 carb tank is the same as a 2001 carb tank so is it a mechanical fitment issue or a electrical fittment issue?, searching the web i read of a low fuel sender fire which upsets the LED from working correctly , if this is the case there should be a fix i would imagine, or i can live with it if its not a biggie, the main thing i want anyway is the gauge to fit even if it dont work properly as i have a paint bubble i need to cover and the trim on the LED guage looks just the thing. Would  be grateful to anyone who has info
    ROb
