Online: speedzter
The handlebar company
  • Sprocket
    Sprocket
    I recently bought some handlebars from the handlebar company based in New Zealand www.thehandlebarcompany.com
    The one I bought was the "new flat and wide bars"  I had them made 900mm wide which is slightly narrower than they normally come.  They cost $110 NZ (about $87 AU) delivered.
    The craftsmanship is outstanding and the finish flawless. If you are after some new bars, it is worth checking out the various ones he does for harleys.
    Very happy with them.  They are currently at the dealers waiting for new cables. Can't wait to get them fitted.
  • als1200
    als1200
    Yeah good to deal with and quick.
  • SoftailSteve
    SoftailSteve
    looks good
  • Sprocket
    Sprocket
    They are being fitted at the moment.
    I'll post some photos when it's finished.
  • Sprocket
    Sprocket
    Here are some photos at Robbos getting the bars fitted.  I could not be happier.
  • wayco
    wayco
    Hi Sproket ,
    Where did you get the neat spotlight brackets?
    Can you get them for 41mm forks ?
    How much where they?
    Thanks Wayne
  • wayco
    wayco
    Thanks for that -they look great.
  • Burraburra
    Burraburra
    Hey Sprocketman,
    Looks like the bees knees.
    You got a good handle on it.
  • Sprocket
    Sprocket
    Thanks Burra,
    Feels good riding with a big bar.
    Maybe that's where the term travel fat came from.
  • Bugger
    Bugger
    This kiwi make some great stuff hes worth checking out http://www.thehandlebarcompany.com/
    Ordered some bars, he made in a week, sent the next week
