Online: Stuart
Labour cost for installing pipes, air cleaner and tuner
  • Merlion
    Merlion
     Hi all,  any idea how much it should cost for labour in installing SE pipes, air cleaner and tuner?
    Thanks.
  • Merlion
    Merlion
     Sydney.
  • daimoh
    daimoh
    Give Trivett Harley a call on 83382120 - they'll give you a quote over the phone. You could also email Deus Ex - info@deus.com.au - they'll give you a quote too. Deus aren't the cheapest out there, but they're actually a great bunch of no BS blokes who'll tell you if they can't do something or if you're mad for thinking it.
  • Merlion
    Merlion
     will do. thanks..
  • daimoh
    daimoh
    Once you've got that ultra-sweet set-up going, do the shocks next - front and back, with Ikons. It made a huge difference to me & my ride, I can't believe I waited so long before doing it.
  • Merlion
    Merlion
    yes. that will be my next upgrd.
  • Oldman
    Oldman
    Do it yourself and save money for the next mod
  • brucecul
    brucecul
    have a go yourself. they are not hard to fit , and who knows you might find it fun, plus the stealers won't get your cash!
  • Rocky2010
    Rocky2010
    Do it yourself, its not rocket science
  • Merlion
    Merlion
     Did a bit of research on you tube.  Will have a go at it myself this weekend.
  • Ross
    Ross
    Just remember when taking your stock mufflers off, WD40 is your friend.
  • Merlion
    Merlion
     noted thanks!!!!
  • calais
    calais
    I just went through the same process modding my dyna, I asked heaps of questions then decided that I dont have a shed full of tools for shits and giggles, so I did it all myself.
    All three items took around 2 hours fit, and I learnt along the way. A dealer would have charged me $600 for their services. Bugger that!
