True Track
    i would like one, does anyone know a stockist in au?
    They work very well, and they are worth fitting.
    Not only for cornering improvement as some people think.
    They help high speed stability as well.
    Try MandM
  • imoo6170
    imoo6170
    I have one by Progressive and found does make a difference - and that is after I had installed good rear shocks and redone the front (springs and oil). Mine is a 1998 FLHT with an S&S 113 so it needed a bit of handling help --:)
