Online: obisteve, speedzter
Alarm and battery removal
  • sophtayl
    sophtayl
    Hi Steve,
    turn the ignition on, pull the 40A fuse. done. Main 40 amp fuse is above the battery close to the fuel tank. You need to remove the cover of the Fuse holder.
    Let me know how you go
    Mick
  • sophtayl
    sophtayl
    Note,
    no need to lift tank off.
    it sits under the seat so should be visible once the seat is removed.
    M
  • sophtayl
    sophtayl
    Cheers Scotty,
    i scanned throgh my pics but couldnt find one....
    Steve- what scotty said :D
    M
  • nobody
    nobody
    As Scotty said,if you remove the battery leads while the ignition switch is turned ON,then you run the risk of spikeing the ecm,it only takes mV to fry the ecm,so be very aware.
    nobody
