Gear oil over full on new road king
  • Two tone
    Two tone
    Helped a mate change the clutch cable on a 2011 103 road king. Had to drop the oil out of the gear box . 2 ltrs came out, the book says 95 or so of a ltr do harleys top it up to the top for runnung in . definatly 2 ltrs came out and its had its first service. Does any body know if it should be topped up with 2 ltrs of fluid.
  • Two tone
    Two tone
    Thats What  I recond  Mr G . we filled it with  the correct amount and its where it should be on the dip stick. Thanks
  • Two tone
    Two tone
    Well here we go sucked in again . now robbos gonna give me shit . my man didnt drain the g box he drained the engine by mistake easy done . but what gives me the shits is that its been in for the 1 st service and the g box was empty . it takes a U S  quart as said  thats around point 9 of a ltr give or take a bit and thats what we put in the gbox to bring it up to the full mk on the dip stick . so I recon serviced or not check your gear oil as well as the engine. Certainly going to check mine in future , its been serviced at the same place but not any more.
