Online: HD17, Hilly
Rear Brake Drag on 2009 Softails
  • HWG
    HWG
    Does anyone else's rear brake drag on 2009 Softail's. Asked about it at dealers only to be told "They all do that"
    My rear disk is too hot to touch after any riding as the pads are allways draging on the rear disk. Changed pads 5,000 km's ago & pads are nearly gone already!
    Rear pads on previous owned Dyna's used to last 20,000 km's
    Any one got a solution to this problem.
    Problem was previously posted in March in the Softail section but no update since then.
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=5&postid=290797&view=topic
  • als1200
    als1200
    i thought i read some where on the forum about this.....do a search. something to do with spacing on wheel bearing? could be wrong.
  • Dave81
    Dave81
    Not a 09 model mate but my 98 had the same problem had to get a new piston kit. The teflon on the piston wich goes into the rubber boot wears out in time and finds it hard to retract back to its neutral position. In saying this i have done 97,000km/s on the old girl.
  • HWG
    HWG
    Both pads are wearing.
