Online: John.R
Where to buy wrinkle black derby cover?
  • 11bigm11
    11bigm11
    Hey guys can anyone give any advice on the best place to buy a wrinkle black derby cover and chain inspection cover for an Iron on the net for a resonable price having a hard time finding one, maybe im just retarded?
  • Shotgunhemi
    Shotgunhemi
    Part numbers are on HD u.s site, I ordered mine throigh mark at M&M when you could. They are called clutch cover blcak and inspection cover black.
    I paid 31 for the derby and 15 for the primary inspection cover-both in USD.
    I dont know why Harley put stock polished siler ones on, looks gay. The first irons were blacked out 2009 I think. I am pretty sure they just wanna make more $ on bits-bastards.
    This was my first 'mod', couldnt stand all black bike with dumb looking silver bits on it.
  • 11bigm11
    11bigm11
    cheers mate what about a new gasket did you bother?
  • Shotgunhemi
    Shotgunhemi
    You will get a new gasket with the smaller primary chain cover, make sure you dont lose the small o-rings on the 2 screws too.
    For the derby cover, nah not needed OMHO. As long as you grease it up with some oil/grease when you out it back on and torque the screws in a crosswise pattern, it will not leak. It will leak if torque settings are not quite right and if tightened up not crosswise cauing it to warp. The large O-ring wont wear out
    Hope this helps
  • nhb006
    nhb006
    Just paint yours... Easy as.
  • Shotgunhemi
    Shotgunhemi
    Or you could paint it, but good luck getting the same finish
  • 11bigm11
    11bigm11
    Cheers guys im after the stock looking wrinkle finish so I bought them cheers for the info one last question can you tell me what the bolts need to be torqued to? I havent got round to buying a manual yet.
  • Shotgunhemi
    Shotgunhemi
    84-108 in-lbs, straight from the 2011 sportster service manual
