Removing rocker covers
  • whitey3177
    whitey3177
    G'Day guys,
    Im looking at buying a pair of chrome rocker covers for my 2010 fxst and am just wondering if there is any real secrets to removing them?
    Im aware that i have to remove the tank and so on and that they have to be torqued up opon reinstallation but is there any thing else apart from correct tention.
    Thanks i advance fellas.
    Regards  Whitey
  • AJ56
    AJ56
    Eady job. But by memory I think you will need an crows foot extension for the torque wrench as you cant get the wrench under the frame....
  • groover
    groover
    Have to agree with Burto above.
    Even tension with an allen key and don't do up the bolts that the threads squeal in pain.
    New quality gaskets are also a good idea.
