Online: Stuart
Cheap tuner
  • oneball
    oneball
    Hi all...Im after a cheap tuner untill the TTS comes out for the 2011 Softails.Can someone recomend a cheap tuner?Something that will suit Slipons and Airfilter.Im also thinking of just going with SERT and be done with it.Any thoughts???
  • JD
    JD
    I think SEPST is better than TTS but thats just my thinking and its around the same price as TTS
  • brucecul
    brucecul
    i use a dobeck pro tuner in my sporty and it is great. i have a big joes in my 2011 fat bob . both work well and are 500 bucks in auss . cheaper from the states
  • oneball
    oneball
    Hi all...Thanks for the replies.Im starting to get a little impatient with my bike sounding like a VW LOL.Haveing the slowest bike doesnt help either.LOL.My heart is set on the TTS Mastertune when its avaliable.
    Hilly,I couldnt find the exide leads on google anywhere.Maybee i need to try harder.LOL.
  • oneball
    oneball
    Hi all...Just another thought.Is there any tuners that dont marry themselves to your ECU ??.Im thinking maybee a second hand one in the mean time.
  • Yositime
    Yositime
    thats Xied .
  • oneball
    oneball
    Hi all...Thanks Yosamite.The correct spelling made all the difference.
    Has anyone tride those Exied leads ?,They seem cheap and nasty.Just what im after.I mite contact TTS and see when the release of the Mastertune for the 11 softails before i by any tuner.
  • HogBag
    HogBag
    Oneball
    Wise call mate. Most tuners work OK on Stg1 kits but fall short when you start getting into engine builds with more cubes, after market heads, throttle body's, exhausts etc etc. Hang in there and wait you wont be disappointed.
  • HogBag
    HogBag
    Thanks Hilly
    Kingchops & Bano must be getting the shits with me spitting the dummy and leaving all the time LOL. It's good to be back on board.
    HB
  • McCabe
    McCabe
    I have just fitted the Xied to my statndard 2011 Fat Bob (Rush slip ons). Made no difference execpt for improved fuel economy arround town. Did not stop the popping issues on decel.
