Dyna Forwards
  • FatRob
    FatRob
     There is a kit, but it says it's only for 2006 up.
    Reduced Reach Forward Control Conversion Kit - Dyna®
    Love the look and riding position you get with forward controls but not comfortable with the long stretch forward? This Forward Control Conversion Kit repositions the Original Equipment footpegs and foot controls up and back by over 1", positioning the controls closer to the rider for added comfort and confidence. The reduced reach places the rider's boot at the proper pivot point for improved leverage, while maintaining the "foot-forward" riding profile. This easy-to-install Conversion Kit includes heavy-duty steel mounts and shortened brake rod and re-uses Original Equipment control supports and brake and shift levers, or can be personalized with your choice of custom lever styles.
    50700005
    Fits '06-later Dyna® models (except FLD) equipped with forward controls.
    FR
  • Deadwood
    Deadwood
    Are they standard forwards or extended forwards that are on the bike currently?
  • Deadwood
    Deadwood
    Might be best to check. If they are extended forwards you may just need to buy standard forwards or in turn you could you put some mid-mount pegs only.
