leaking front brake
  • hammerhead
    hammerhead
    gday fellas i have a leaking front brake and no matter what i change or swap around (dual front brakes) the same side keeps leaking. these brake calipers are pro1 and have not done that much work. the pistons dont seem worn and i have replaced all the o rings with aftermarket ones that were slightly thicker in diameter and same side still leaks. any ideas. the only seal not changed is the tiny crossover one on the join of both sides.  cheers woody
