Online: HD17, Hilly
Ticking sound
  • McCabe
    McCabe
    I have only had my Fat Bob for a few months (brand new), love it. Is the ticking noise you can hear at idle and low revs normal, I assume it is just the Hydraulic lifters I can hear.
  • Aussie Dave
    Aussie Dave
    could be your fuel inejectors opening and closing
  • HWG
    HWG
    Could be your loud watch?
  • the_mongrel
    the_mongrel
    You are lucky!! I have a swarm of locusts in mine!! LOL!!! :)
  • russ4570
    russ4570
    OH my god it's a BOMB! quick ride away as fast as you can - at least as far away from me as you can!
    Russ
  • Heres_Ricky
    Heres_Ricky
     Tick tick tick
    worry when it stops
  • FXDF08
    FXDF08
    Mate, check the exhaust header shields.  You'll find they're lose and making the sound.  I know you think that's crap, but hopefully will fix the problem.  I had to go to Bunnings hardware and buy a new stainless clip (same as used on any hose), which fixed my problem ... but then I still replaced the pipes, air filter and tuner!!! Now that's definitely the way to go!
  • Burnzi
    Burnzi
    I am a Bomb Specialist........if you see me running try to keep up!!
  • SoftailSteve
    SoftailSteve
  • groover
    groover
    Hydraulic lifters.
    Treat it like a diesel.
    If it goes quiet, start to worry.
