Best Prices for gear
  • whitey3177
    whitey3177
    G'day fellas
    Can someone point me in the right direction for the best prices for Vance and Hines 2 into 2 big radius pipes and Kuryakyn Hyper charger.
    Also How do you know if the pipes ya want will fall withion the guidelines for noise pollution?  I dont really fancy spending good money for something the cops are gunna make me take off due to being to loud. And what is the maximum height for ape bars in NSW?
    The Whitesnake
  • FXSTC 09
    FXSTC 09
    If you want to stay legal you can forget running vance and hines big radius pipes as they are really loud pipes.
    If you do have your heart set on fitting them just hang onto the stock pipes to get any defect notices lifted as swapping pipes over is only a half hour job.
  • whitey3177
    whitey3177
    Thanks for ya reply scouser/Fxstc.
    Thats a bit of a bummer not being able to chuck the big raduis's on as the would have looked mad but i dont fancy being pulled over every timei ride past the police either.
    Any ideas on a good looking (quiet set) of pipes out there?
  • Hooky
    Hooky
    Been done twice for my V&H big r's. Once in Sydney, Once in the hunter valley. I see it as a minor inconvenience compared to 'not being seen and heard' by other motorists.
    Sort of like an audiable yellow hi-vis vest.
    Plus, they look good and sound like a Harley.
  • mickle
    mickle
    Agree with Hooky,if you take it easy you can keep the noise down but if they want to defect you they will find something.Fuck em put em on.
  • jacks
    jacks
    mandmcycles.com I have the V&H straightshots and as long as you don't hoon past the coppers you should be ok....oh I have the quiet baffles fitted (-3db) they are half the price than here incl delivery...got mine in 5 days door to door....
  • 04sporty04
    04sporty04
    I second the vote for mandmcycles.com...just note the price that he shows on his website isn't the price he sells it for...you have to submit for quote to get the discount price...MAP policies prevent most sites from displaying prices below MSRP...
