Online: Stuart
service
  • beerman
    beerman
    took the superglide for a service, replace leaky outerprimary gasket and other seals while he was there, and heavier weight oil in front forks. i supplied primary gasket and seals and oil filter. he supplied engine oil (gave me remainder), put nice sticky stuff either side of primary gasket (apparently previous had jack), replaced other seals (made sure tower gasket wasnt half a hole this time), then pulled out front forks, did a bit of research as to original oil weight and went up five and put the stuff in. i said thanks very much, what do i owe ya,   $200.00, is this sayin somethin.   p.s the blokes had harleys, beulls, triumphs and wotnot, friendly races every now and again so he must have a rough idea
