How low can ya go
  • gragra38
    gragra38
    Newby here, going to by my first Harley in a couple of weeks, a Sporty 1200 custom, but as I'm a real shortarse, I was wondering if anyone can tell me how much lower could I drop a 1200 custom, I intend to get a super reduced reach seat for it, but every inch helps. hope someone can help me out.
    Cheers, Graham.
  • terroristone
    terroristone
    When you say short, how short? I'm 5"6' and i use 11" rear shocks and can go flat foot, sometime i put on my 1" lowering blocks as well to really drop the ass....
  • terroristone
    terroristone
    i might be interested in a swap for my mids!
  • gragra38
    gragra38
    5'2", so pretty short, I can reach the forward controls no probs, I'd just like to be as close to flat footin' it when stopped. Is 11" as short as you can go in the shocks? what's the lowering block you mention, haven't heard of them, did ya lower the front as well? sorry for all the questions just trying to get this right.
    Cheers, Graham.
  • terroristone
    terroristone
    you can find 10.5" shocks but they are rather harsh from what i hear. http://www.ebay.com.au/itm/BURLY-SLAMMER-LOWERING-SHOCKS-HARLEY-SPORTSTER-04-10-/150664560944?pt=Motorcycles_Parts_Accessories&hash=item23144ec130
    the lowering blocks basically shift where the lower bolt hole is on the shocker, it ,moves it back an inch thus making the bike lower, but you will bottom out over hard bumps.
  • terroristone
    terroristone
    Yep thats one thing i forgot, i do drag my exhaust when i push the corners. also have a good look into seats, my lepera barebones brings me forward an inch and is one of the lowest seats available.
  • r0880
    r0880
     Standard height (12.5" shocks on custom from memory) clearance isn't great, I can just clear gently dropping off curb onto road, and have scraped more than a few times on driveways and speed bumps and broken the side stand spring lug off.  If you can get one foot flat with other on peg you should be alright.  I personally wouldn't go more than an inch lower in suspension.
  • gragra38
    gragra38
    Thanks for the replys, all that info has helped heaps, as soon as I get my bike I'll post some pics, and start looking for some rides to go on.
    Cheers,
    Graham.
  • kevlad
    kevlad
    im 5 6 i had 11 s on the arse end loved the look loved that i could stand flat footed still have them in the shed for sale XLH1200 screaming eagle 11
  • gragra38
    gragra38
    Kevlad, hang on to those shocks for a couple of weeks, and I might buy them off you.
    I've sat on quite a few bikes (sportys) and none of them let me touch the ground perfectly, the closest I've come was one on the weekend in the city, I was told it was a 1200 custom low, import from the states, not doubting the import side of things, but I've looked long and hard since and can't find any refference to that model, so I'm guessing it's just a custom with lowered shocks. The price was a bit steep, and an '07 model with 800 ks, sounds off to me.
  • r0880
    r0880
     They replace the speedo as part of compliance.  No such thing as custom low, theres a 1200 custom and a 1200 low.  How much?  They seem to be around US$7k on ebay, plus couple grand freight, couple grand compliance, bit of mark up, so what $12-13k?
  • gragra38
    gragra38
    They were asking 17,900, it had a fair bit of bling, but I thought it was well overpriced.
  • slapster
    slapster
    Seems to be an abundance of them. $13k - $15k.
    http://www.bikesales.com.au/all-bikes/results.aspx?Ns=p_IsPoa_Int32%7C0%7C%7Cp_RankSort_Int32%7C1%7C%7Cp_HasPhotos_Int32%7C1%7C%7Cp_Make_String%7C0%7C%7Cp_Model_String%7C0%7C%7Cp_YearMade_Int32%7C1%7C%7Cp_PriceSort_Decimal%7C1%7C%7Cp_PhotoCount_Int32%7C1&N=1432+604+1430+1429+1626+1428+4294967260+4294956053&TabID=1409178&keywords=&Nne=15
  • Rocky2010
    Rocky2010
    My Partner is a short arse and she can stand flat footed when she is on the bike, she has Progressive 430 11" shocks on the rear of her 883 Low.
  • kevlad
    kevlad
    check my pic it still has 11 s on it in the pic sat very nice i loved the look loved the way it felt only changed them because it was a bit hard on the missis im 120 ks she is 75
  • gragra38
    gragra38
    Yeah I reckon yours looks great kevlad, just what I'm after.
    Scouser, you might be right, but I just like the look of the customs and lows better.
    can anyone tell me if the only difference between a custom and a low is the forward controls?
    Cheers, Graham.
  • kevlad
    kevlad
    have the low seat of mine for sale aswell it will help get your feet closer to the ground
  • gragra38
    gragra38
    What sort of seat is it? where abouts are you Vic?
  • kevlad
    kevlad
    2 piece as in pic original from harley but it did sit nice and low live in warrnambool your welcome to come have a look
  • gragra38
    gragra38
    Thanks Kevlad, I'm in Cranbourne, got a bit the next couple of weeks but see if I can make it after that.
    Cheers, Graham.
