Online: tussuck
Induction noise FLHT
  • beagle
    beagle
    I'm thinking of putting an SE air cleaner kit on my 103 which is already fitted with SE touring cans. I have heard comments about excessive induction noise bouncing back from the batwing from the SE air filter kit.   Is this an issue with those who have done it? My other option is a KnN stock hi flow filter that fits into the existing airbox which is less intrusive. Any  advice is welcomed.....beagle
  • Rick1310
    Rick1310
    I have the S&S twin system on my 07 streety & I have noticed any noise but it looks good & works well.
  • beagle
    beagle
    Ended up sticking the KnN stock profile filter in with a remap. Huge difference.
