Arnott air dampers
  • shovel1340
    shovel1340
    Hi,
    I bougth some air suspension from Arnott in Florida, USA. For 980$ i got the suspension special made to be as low as possible when to the bottom and high enough for the longer rides. The set came with shock absorbers, a small compressor, tubing/fittings, a magnetic valve and a 2 buttons panel to put on the handlebar for rising and lowering the bike.
    After 4-5 hours everything was fitted to the bike. I hide the compressor under the oil tank and the result was like this:
  • Filthy
    Filthy
     That's a sweet looking Shovel - any more photo's ?
    What sort of exhaust have you got - judging by the angle of the bracket when fully lowered there won't be a lot of clearance.
    Nice work
    Philthy
  • shovel1340
    shovel1340
    Thanks,
    I have problems by uploading pictures this morning (Norway) - I will try to upload later.
    You will find a complete project report with pictures on htis bike under projects on www.eriksbikeworld.com
    Have a great day
    Erik
  • shovel1340
    shovel1340
    Hi,
    Here are some pictures
