No spark
  • FatboyGooch
    FatboyGooch
    Howdy,  Same problem christmas eve ,  bike started on the weekend  than stoped,  no spark  plugs & leads are good had coil tested it is good orange light on speedo goes out after 4 sec . checked fuses no problem  taken starter relay out put back in  checked in around TSM  that  all the knowledge i have . Will i have to put it on a trailer and take it to a tech in Geelong .  pissed off   any suggestion would be greatful suck living so far away , when shit like this happens.
  • FatboyGooch
    FatboyGooch
    Thanks ozroder  for the advice definitely a spark problem.
  • FatboyGooch
    FatboyGooch
    Ozroder , taken nut of fuel bowl petrol is pumping through,checked all wiring, no fault codes as well.
  • FatboyGooch
    FatboyGooch
    Just letting you know bike is running agian ,bike needed recalibration, bike was a import from japan  , 2004  Carby Fatboy purchased 2 years ago  . I have been doing my own oil change because I dont take it to a dealer its has missed out on the lastest updates for the ICM  VIA   DEGI TECH . Was told something wasnt changed to suit Australian standards . not sure what they were talking about . any way it running again. cheers ozroder for your reply
