GPS
GPS
Markle
Hello
How do you connect a GPS and can you use any model off the shelf? Have a navman.
Thanks
AJ56
As in power connection? You would need to splice into an orange/white stripe accessory wire on the bike. it depends on what power it requires as well...
SoftailSteve
I use weather proof cigarette plug the bit with the yellow tape around it .I have got a fuse next to it {red fuse} have it tucked away next to my battery was going to make a bracket near the handle bars , but it has been that way for the last 5 years .it works fine for me.
