Sportster clutch problem
  • the angry german
    the angry german
    hi guys wondering if anyone out there got and ideas of what i can try to fix this
    i got a 86 xlh 1100 and the clutch was slipping so i changed the friction plates and the steel plates
    friction plates i got from barnett , steel plates from alto i re used the spring plate [ double steel plate ]
    clutch was still slipping after that so i got a new diaphram spring and fitted that
    it appeared to be ok when i took it for a test ride but after about 10 km started slipping again
    i used genuine hd formula + transmission and primary case lubricant
    hope someone out ther got some ideas as iam about stumped
  • Tmode
    Tmode
    Is the clutch cable adjusted properly according to specs? Maybe it needs replacing if it's old.
  • the angry german
    the angry german
    i dont think it can be the cable as
    if the cable would be stretched it would be hard to get it in gear due to the clutch not disengaging properly
    but that should not cause it to slip once in gear
    cable too tight could cause clutch to slip but i would think that that would have been from startup onwards and not after about 10 km into the test ride
    but i will check it tomorrow anyway
  • Rocky2010
    Rocky2010
    Did you soak the new clutch plates in oil for 24hrs before you installed them, also make sure there is free play in the clutch cable has the required free play, is the clutch adjusted correctly.
  • the angry german
    the angry german
    no i didn't soak the plates for 24h.
    according to the manual your supposed to soak them for 5 minutes which i did
    i went through the setup as per the manual
    going to pull the whole thing apart again and start from square one and see how i go if that wont do the job i take it to a workshop and have it looked at
     if the clutch pack  is good , then it must be the way it's adjusted , back the cable off  too 1/2 lever slack only , adjust  down on the adjuster screw  & lock nut as just off  buy 1/8 to 1/4 turn loose , make sure the  3 balls in  the ramp release mech are in place  1st , then adjust the cable too 1/8 "  slack take it for a gentle ride  , let it cool down & then reajust again,
  • DynaRider
    DynaRider
    No clutch pushrod in an xl, so no bearing like a big twin.
    Adjuster screw mounts into a ball bearing, in a carrier.
    A frequent cause of clutch slip is the spring plate. That plate is not essential for "lock-up", but it is good for smoothing the clutch take-up, and preventing the clutch from being excessively sensitive upon release.
    There are many areas of assembly that could lead to slippage, so very hard to say without seeing.
    The centre screw adjustment is a key area, that needs to be correct.
  • the angry german
    the angry german
    cheers for the help guys
    finally got it working
    i learned the hard way that the centre screw adjustment is very critical , a quater turn either way seems to be either to much or not enough
    pulled it all apart again to make sure everything was ok then took it for a ride and kept on making adjustments till it was working properly
  • reece1804
    reece1804
    Mate, I have just been through a similar wild goose chase with my sporty thinking there was something wrong with the components with in the clutch only to find it just needed bedding in around the block a few times! Had the bloody primary off 4 times.
    Found a thread on a Yanky HD site that said if your clutch is not engaging after you've had it apart of it's been sitting round for ages just warm the engine up, roll it down the driveway, kick it into 1st and away you go. After the oil has heated up and penetrated the plates properly it will come good. Strangely this worked in my case.
    Good to see you sorted yours out.
