Rust/Discolouration Fuel Filler Neck
  • 48fan
    48fan
    Im pretty sure if you ask HD they will tell you its "a Harley thing"
    I wash mine less now ,Id rather the dirt than rust ....the dirt hurts but the rust kills me
    Also check your welds ,I had to touch up one on my swing arm
  • Rocky2010
    Rocky2010
    Try and keep your tank full as much as you can, also don't use ethanol blended fuels as it absorbs moisture.
  • brucecul
    brucecul
    mine went the same too looks like shit . i was told the hd thing as well as the chrome too , keep an eye on pipes etc too
