E C M
  • Finny
    Finny
     Can anyone explain how ya check ya ECM, Im Getting no spark to my coil, I've checked my coil,leads and spark plugs to another bike and there fine.
    I Have a 2005 ultra glide, if that helps.
    Cheers Finny
  • Finny
    Finny
     Well i tried a new computer and that didnt work, I cant understand why i have no spark.
    Ok So i did some head work, Put in a set of cams took it for a spin and found there was no oil getting up to the heads, Pull it back down to find i
    had the lifters ass about, Put it back together , go to start it and it wont turn over, I have no spark , I have taken all my gear (coil,leads,plugs, relays)
    and tested them on another bike, All fine, then i thought it might be the ECM, But no tried another 1 of them and still nothing. I have stripped down
    the wires to see if 1 of them was split or broken but could not find a bloody thing. Mutherfuckincuntwhoremoleslut of a thing. So its on the trailer to
    go to a Auto Elecs, to see if he can find a problem, If not im buying a bag of Marshmellows.
    Finny
  • terroristone
    terroristone
    fuse? is the ecu getting power? coil getting power?
  • OzGlide
    OzGlide
    Check the TSM and make sure its not tilted. Can you hear the fuel pump priming ? No pressure no spark. Check all the earth wires from the battery frame, gearbox etc. Make sure the battery is good under load.
  • Finny
    Finny
    The auto elec rang and said there's pulse going into the computer but no pulse coming out ?
    He has gone through all the wiring harness from computer to the coil and can't find a fault ?
    Its got him even Baffled,
    Finny
  • OzGlide
    OzGlide
    TSM Turn signal module has a bank angle sensor that shuts the motor down if bike is dropped on its side. If that's not sitting square it could be your problem.
    TSSM come on bikes with a harley alarm. turn signal security module also has a bank angle sensor.
    A lot of Auto elec's probably wouldn't know what to check on a Harley apart from the obvious..
    You really need some form of HD diagnostic tool to check proper sensor operation.
  • Finny
    Finny
     If anyone could help me out with the wiring diagram , would be much appreciate,
    I did order 2 from the states but not 1 arrived, One of the sellers sent me a second at no charge, so thats 3 but none arrived.
    all three tracked to SYD and nothing from there to Melb.......Someone upstairs hates me?
    Regards FINNY
  • OzGlide
    OzGlide
    Finny
    If your bike has no alarm it has a TSM so check to see if it's mounted straight and not on a angle. Does your bike have a PC3 tuner ?
  • OzGlide
    OzGlide
    Finny
    I will check my bike for the location of the TSM. I would also check inside the fuel tank to make sure there's no split fuel lines or a blocked fuel filter as a drop in fuel pressure will cause the ECM to cut spark to the coils. If the TSM and fuel supply are OK the ECM could be stuffed. Any dealer could check your ECM system with a digital technician so you should consider this before spending to many dollars.
  • WozzA
    WozzA
    it's POSSESSED ...
  • Scrumpy
    Scrumpy
     How old is the battery? Maybe starter is robbing power. Is the bike injected or carbie, if injected check if injectors getting surficient power.
  • Finny
    Finny
     Well Just like to thank everyone for the input,
    The sparky caint find anything wrong, He has stript wires , He has checked everything, not once but twice and three times, Auto elec and his mate thats a Machanic say it must be machanicle problem, So when i pick it ill strip it back down and see what i have done.
    Thnx again, FINNY
  • FatboyGooch
    FatboyGooch
    Howdy Finny I just  after mine just cut out needed to take to a dealer to get  ICM  updated VIA DEGI TECH  bike now has the lastest down load my bike is a 04 carby fatboy  I am confused maybe i will have to take in once a year  to  have it  diagnosed.
  • Finny
    Finny
     Well im picking up the bike tomorrow, the atou elec has found i dont have compression, back to the drawing board.
    thanks to everyone for there help.
    But i might rack ya brains soon
    Cheers Finny
  • OzGlide
    OzGlide
    Finny
    Do a compression test dry and then add some oil and do again. Let us know what you get.
    I still think it's electrical as I know of a few TC bikes that have done over 200.000 K's with no top end work.
    Good luck
