Online: HD17
Baisley Tapered Pushrods
  • 2005 FLSTFI
    2005 FLSTFI
    Anybody used or running these.
    What are your thoughts/opinions or should I just get the SE Tapered Adjustables.
    Thanks for any input in advance.
    I put TW7's in my brothers 103 using stock beehives with zero problems.
    The stock beehives are better than most people think.
    And for the sake of only another $150 or so, cheap peice of mind I guess.
    How much are the Baisley pushrods ?  I've got the SE tapered to go in my Tman 625 build, If I ever get my bike back from Insurance !
  • GMR-PERFORMANCE
    GMR-PERFORMANCE
    We have Smith build ours as well but not in a taper, we have seen them hit the tubes thus we have ours built in a 3/8 straight, extra room on the top tip for higher lift cams with out binding issues. Push rods are 109 for a set or 176 with a complete new tube kit, not just a partial kit. On the older bikes the springs start to get weak etc, so the kit has all new parts top to bottom for a easy install and no leaks, as all the o rings and seals are included as well.
    Smith Builds a killer product,.
