Is there really a need to ..........
  • FrankW
    FrankW
    change cam bearings when fitting new cams?
    I have a 2010 Super Glide Custom that I want to fit with aftermarket cams.
    I am still looking at which cams to fit, I do a lot of 2 up riding so I am looking at something that suits that purpose.
    I already have the Stage 1.
    Changing the cams. won't be a problem mechanically.
    The bike has only done 7000 Klms. so is there any need to change bearings?
    It isn't that bearings are matched for any particular cam.
  • FrankW
    FrankW
    Burto, Thanks for the link.  Point taken.
    Will definitely change the bearings when I decide which cam to fit.
