Online: Retroman
combo speedo tacho
  • softail09
    softail09
    Hi Guys
    looking at a speedo tacho combo any sugestions please .
    Smokey
    noosa Haeds qld
  • softail09
    softail09
    Hi Guys
    I done well got my new combo speedo at Biker Life Marrochydore cheeper than the local HD dealer.
    Smokey
  • Rocky2010
    Rocky2010
    Fitted one of those new Speedo/tacho on my Fatboy Lo, looks great nice fancy colours which is a bit of a wank but it does look nice. Clean look about this speedo much nicer than the stock HD speedo.
  • Rocky2010
    Rocky2010
    Yes that unit will fit your 2010 Fatboy
    I have it installed on my 2010 Fatboy Lo
  • Rocky2010
    Rocky2010
    Yes I installed it myself very easy, also the instructions which come with the speedo/tacho are easy to follow.
    I have also installed the HD Guage Visor Ring which goes over the 5" Speedo. Originally the Visor Ring is Chrome, as I am trying to remove the Chrome from my bike I have shot blasted the chrome visor ring with garnet then primed it and it is now painted in Black which suits my needs. Many may not like the blacked out look but for me it is the way to go
  • HWG
    HWG
    Just ordered one myself! Like what you've done with the fuel gauge/petrol cap.
    I am thinking of using the Willie G petrol cap medallion on both.
  • HWG
    HWG
    Orderded one from my local dealer in Brisbane a week ago, says no stock & many on backorder & cannot give me a delivery date!
    Harley-Heaven do you have stock & can you give me a price delivered to my address in Brisbane?
  • LordViykor
    LordViykor
    They're a great speedo/tacho combo I fitted one to my Softail. The 600 settings is a bit of a wank though, you have variations of colour like light red, red, slightly darker red etc. All up there may be 600 variations it's still shades of primary colours mostly.
  • the_mongrel
    the_mongrel
    My gear indicators work from 1 to 6 so maybe it is your ECM and yes they should be freaking standard.
  • softyJ
    softyJ
    I revieved my speedo/tacho combo yesterday from HH and installed it last night. Looks great and cant wait to get out and see if it all works.
    Thanks for the great service Pat.
  • softail09
    softail09
    hey rocky love the cover around the speedo mate is that part of your dash or are they availible to purchase .
    Smokey
  • softail09
    softail09
    Smokey
  • Fatboy80
    Fatboy80
    Hi Guys
    just fitted mine on friday had to wait a few weeks HD out of stock lots of back orders, easy to fit have Thunder Max auto tune as well gear indicator does not seem to work only shows 6th will keep playing with the set up just love the look trying to find a colour combo is a nightmare way to many in daylight it is not that bright but looks way cool at night, need to get some covers for the original fuel cap looks crap now HD mechanic wasnt sure if it would sync up the odometer becasue of the thundermax but no problems he said 2 other didnt work had to refit original ecu download and then refit t/max might have been the way they did it. great bang for the bucks
