Need help with ignition switch please
  • ElDubya
    ElDubya
     Okay, I need to know if I can swap this :
    with this :
    The bottom one only has the 3 poles for ignition, lights and mains, whereas the top one has the 3 poles PLUS 6 small tangs around the outside that need to be jumped from other parts of the switch.
    Does the top switch have all the jumpers already connected?
    Any help greatly appreciated.
  • The Don
    The Don
     G'day Eldubya,
    What you have is one 1936 to 1995 ignition switch (the top one ).
    And one for 93-2005 Wide Glide, 96-2006 Softail and 94-2006 Road King. (the bottom one).
    They are not readily interchangeable from new to old style.  Although you could use the new switch
    on an old bike with a bit of easy re-wiring . The other way would be too much of a pain. Why?. Not worth the effort.
    Cheers,
    Cris.
  • shaggz
    shaggz
    If you only want to change it so that you can use the round key you can buy one through J&P Cycles that has the old style base with the newer round key. I have bought one for the Shovel, Just haven't got around to fitting it yet.
