Online: tussuck
how to use fob with button
  • Derek
    Derek
    i have just bought a 2006 FXSTI before that i had a 2010 1200 custom , with my sporty i had a fob which did not have a button but my soft tail has can anyone explain how it works ive tried pushing button once and i moved bike (no alarm than i tried pushing button twice  i did see indicaters flash but still no alarm when i moved bike ? please explain also not sure how to set clock i tried indicaters still no change
  • Harvey Mushman
    Harvey Mushman
    Cant help with the above as the only fobs I have seen have been buttonless,but  I would be curious as hell  to find out why you werent given 2 fobs,and where the second fob is located.
  • Derek
    Derek
    Worked it out Harvey to arm security you hold button in for 3 seconds and to disarm you push button 2 times , i was given 2 fobs both have buttons i think they changed after 06
  • HWG
    HWG
    Yeah mate after 2006 they changed to inbuilt proximity switch in remotes, before was manual arm, myself i prefer the old push button method
  • Flak88
    Flak88
    At least you can change battery in old fob without system having a fit.
