Online: Retroman
TAB non-baffled slippons, do they comply?
  • ralphski
    ralphski
    I have to take my NRS '10 to get checked out on/or by the 27th Sept. I have TAB non baffled slippons fitted. I'd be very surprised if they pass any ADR noise requirements. Any ideas?
  • vmax
    vmax
    Ralphski after riding behind you the answer is no !!....you will need to put the ugly originals back on..Remember they charge per visit and if they can get you back there they will
  • Soapbox2627
    Soapbox2627
    I will guess your pipes will be too loud
    why dont you go to an exhaust shop and have them tested, even if they are to loud , you will know if ever you are pulled up for the field test.
