Online: tussuck
VPC 92T
  • 2005 FLSTFI
    2005 FLSTFI
    Anybody running these.
    What are your thoughts/opinions. Are they worth the coin.
    Where did you get yours from? Sent 3 emails to AIM in 2 weeks & not 1 reply. They musn't want any business.
    Thanks for any input in advance
  • 2005 FLSTFI
    2005 FLSTFI
    Hey thanks for your input guys.
    Just found out Latus HD sell the VPT 92T as well as the LMR-002 spring, so its win-win for me.
    They work good, i know a few that use them, also the Destroyers have that type pressure plate, you can play with the weights to get the clutch to work how you want. you can also use a real light spring so it's easy to pull your clutch in & the vpc puts pressure on the plates as motor revs to stop clutch slip.
    we had one guy who has had clutch troubles for some time,  then he wewnt with a VPC and he is runing low 10's now
