(Beware) & Got a new headlight
  • Dermie
    Dermie
    I posted here a little while ago regarding getting a new headlight.
    I ended up going to a Hella distributer to see if I could get a new insert for my standard 05 Sporty 1200c, they had a really cheap one for $15 but i was not sure if it would fit, anyhow long story short went to the local HD shop & he had a look at mine & noticed that the reflector was very hazy, sort of smokey. I knew this also, he showed me a new one & said that it would be a lot better than the one I had & if I wanted even more light that he had some Phillips globes that would fit in there that will be ok & light up even better. So I bought the HD replacement ($160) insert , but did not bother with the globes yet. It is a lot better than the one that was in there so I thought well that was not too bad, its not fantastic but good.
    Well anyhow I was about to chuck the old one away in the bin & put my finger in through the bulb hole to see what the hazyness was on the inside of the reflector only to find that it came off straight away with a stroke of my pinky. I don't blame the dealer for selling me a new one, after all it is his job.
    So beware if the inside of your reflector looks a bit dull try your finger & maybe a bit of cloth. I reckon that a bit of moisture has got in there & the heat of the globe has just laid a light deposit of something on the reflector lining.
    So now I have an extra reflector & an thinking of putting on dual headlights one on top of the other  and am looking for a Sportster headlamp shell, rim & bracket, anyone got one for sale????
  • als1200
    als1200
    bugger, glad you didnt buy the cheap one, they are shit (but you get what you pay for), cant beat the quality of the Hella inserts (good reflectors) or even some of the new polycarbonite type coming out now. do the phillips globe for a std upgrade, heaps better (ask for the plus 100) as i have had really good feed back from a couple of bike riders (jap), you will wonder why you didnt do it ages ago.
