new rings or oilpump
  • evoshovel
    evoshovel
    I have a bike with a 1993 evo motor . If its not started for a week it pours oil out of the engine breather. Also it blows a bit of smoke now and then.I realize it might be wet sumping but could it be just that the bore is so worn that the cases are being presurized and pumping the oil out or could it be mainly the oil pump.
  • houli
    houli
    It could be the check ball seat in the pump and wear in the scavenger part of the pump or just a dirty ball. Start one thing at a time, clean the ball and seat, go for a ride and then check compression, are your plugs oily?to fix the seat of the check ball remove the pump and regrind the seat using an old push rod and some fine grinding paste, grind until you get a full dull grey ring, clean clean clean, while the pump is out check the housing for any scoring round the gear housing.
    After you check the compression squirt a bit of oil into the chamber and recheck compression, if it jumps right up the rings/bore are worn.
  • evoshovel
    evoshovel
    Thanks Houli I will pull the oilpump off this week and give it a service.
  • als1200
    als1200
    Gee evo I thought we might have been going for a ride on Saturday, hope it's nothing major, hate to see the legionary rocket off the road. If you need some moral support, give me a yell, I've got a few nights off early this week.
  • evoshovel
    evoshovel
    Im back to nz this weekend I hope to be back on the road before next weekend so we might get out for a ride.
  • als1200
    als1200
    Good stuff
