SE204 CAMS & TTS
  •  GLEN
    GLEN
    I am going to put some 204 Cams in my 96 cube twin cam, I have the TTS, I was just wondering do I need to change any base map or timing as these are bolt in cams ???
    If I need to change the map what do you suggest as a good one to put in before I get down to the coast for a dyno tune
    I also run the moflo air filter and D&D fat cats
    thanks slugger
  • AJ56
    AJ56
    You will need to recalibrate the map that you are using atm with the cam settings for that cam. Do a cam analyzer then Vtune as these will be affected. You might find that it will run like a pig if you just leave it like it is until your Dyno.
  •  GLEN
    GLEN
    AJ56 or Dev1 would you be able to point me in the right direction as to where to start, or what map to use and where to get it - as I dont know anything about this - I was just wondering if someone could give me a map or show me where I could get one, so I can give it to the mechanic who is going to do the job. Your help with this would be much appreciated.
