jet size ?
  • WozzA
    WozzA
    I was running much the same set up as you BUT with the CV carb...
    46 Idle & 185 Main worked real well 4 me..
    Whats jets are you running now ? CV sizes are diff' than a 42 Mik'
    You should be looking at around a 20 to 25 Pilot, and a 160 to 165 main.
    Tuning guide here: www.mikuni.com/pdf/hsr_tuningmanual_021003.pdf
    I'm running 20 pilot and a 170 main on warm 95. I tuned it with a Wideband AFR meter.
    What rev range do you think it's lean ?
    I guess you've tried richening the Idle mixture screw ? You could try 1 richer on the Pilot.
    I find it all guess work, unless you know the actual AFR's.
