Night Train 2009 Conversion to chain and sprockets
    The problem is the Gear Box Sprocket, 07 and up HD Changed the Gear Box Spline and I dont belive any one makes a Chain Sprocket that fits, If it was a 06 and down the parts would be about $350.00 in Parts
  • hellboundpig
    hellboundpig
     How mutch belt deflection do you have could be way to tight and do you dump the clutch often.
