Online: baldy1450
My First Build
  • Iron Head
    Iron Head
    Hi guys
    After alot of stuffing about set backs and so on
    I have finaly started my build
    It started with ordering a custom built frame to suit my iron head from the states and had ended in a 300 rear long low chop
    Im from Victoria so rego is painfull here
    I will try and update with pics along the way and hopefully get some tips and tricks from you guys
  • Iron Head
    Iron Head
     Here is a quick mock up - not using the rear wheel or tank
  • Iron Head
    Iron Head
    The frame
  • Iron Head
    Iron Head
  • Iron Head
    Iron Head
    I have a collection of wide arse wheels just not sure what to go for
    Will rego it with these for a start anyhow
  • Iron Head
    Iron Head
    Avon 300 rubber
  • Iron Head
    Iron Head
    Fender Blank
  • Iron Head
    Iron Head
    The main Purchase
    REVTECH 100
    Hopefully reliable and rideable
  • Iron Head
    Iron Head
    Couldnt afford the fully polished motor :(
  • Iron Head
    Iron Head
  • Iron Head
    Iron Head
    Just playing about on the bench at work
  • Iron Head
    Iron Head
    Another big purchase done - The BDL TF2000 open Belt Drive
    Going to have to sort out a guard for rego
  • bertiebettle
    bertiebettle
     Looking forward to seeing it progress.
  • Iron Head
    Iron Head
    Hey Chopaweeza
    The pointed crap will go when i mount the tanks and so forth Im not a fan of the look
    Its within the 550 its bigger in the pic as it has a peice of broom stick as the neck stem which is loose
    I read plenty about the Revtechs and the issues prior to buying but the later 4' x 4' apparently fixed those problems either way its new and its a start my pockets arent that deep - I did make sure the belt drive is good enough to suit any engine I may afford in the future
    Im building this bike on a budget its not going to be a show winner BUT it will be finished and engineered for under $10,000
    Your message was very blunt - you were very helpfull about a year ago when I started looking into the whole ICV deal
    lets hope I can get some more of that
  • SoftailSteve
    SoftailSteve
    looks like a lot of bike for under $10,000
  • Iron Head
    Iron Head
    Well $10,000 the figure im sticking with finished engineerd (without the enginners bill) - I will have to build it to rego then pull it down and make it look pritty - im handy with a spanner a welder and a spray guy
    But im hoping to use the guys on here for some extra knowlege and tips and trick so it goes smooth
    Im lucky enough to have a good contact in the states to help pack and send my stuff here
    Thats why I bought the 100CI Revtech as its a cheap power plant
    BUT Ive just spoken to my engineer and he wants something to say it complies to 2011 emission standards ?
    I can fit everything to make it comply but there is nothing from revtech direct for australian standards - did you ever have this issue chopa?
    Main PURCHASES
    Frame $1500 ( Long Story but diff frame to what I ordered )
    Motor $2000 new unused 2006 mod
    6speed $700 ultima yet to purchase
    BDL TF2000 Drive $1000 new unused
    300 Spoked Rim & Tyre $700 new unused
    Forks (have already)
    Loom $250
    Rear Guard $200
    I have alot to go but as chopa said I have a bank of parts to use, swap and sell
    SO SOMEONE BUY MY SPORTSTER MOTOR IN PARTS FORSALE to fund my next stage
    Find a diffrent Engineer, There is no requrerment in the ADR'S for 2011 Emission Standards for a ICV Motorcycle
  • Iron Head
    Iron Head
    Hey Walka
    I called and emailed your man Peter like a year ago when we spoke about my iron head build and he isnt taking new customers even if I was referred :(
    New guy seems good on everything else other than the engine - has looked at my build plan and spent an hour with me at no charge will quiz him harder on the motor as I have paid for the revtech
    Your new build looks mad wish I had the coin for your motor
    While I have yours and chopawezza's attention
    Is Jokey shift - 100% a no go seeing as I need to have both hand on the bars?
    Can I use Jap bike brakes (front calipers) without ADR issues - or should I stick with HD gear as the weights are the same?
  • Iron Head
    Iron Head
    El Skitzo - Nothing mounted yet
    It came with a basic spiggot and all thread set up that I have to mount but I might have something a little nicer than what I have machined up
  • Iron Head
    Iron Head
    10K is the go man - Im determined to keep it under that aswell
    The whole ADRs lights , Reflectors and all the ICV requirements are on a tick box check list issued by vic roads so thats made the head aches a little easier
