New upholstery/padding on seat
  • Dicey
    Dicey
    Anyone had this done? Whats a rought guestimate of cost? My sportster seat is shite so want to get it reupholstered with some extra padding added. Yes I know I could buy a whole new seat but figured its a bit easier and cheaper to get the original re-done.
    thanks.
  • 883n Harley Convert
    883n Harley Convert
    Not too sure what it would cost, depends on the cover you use....................leather would probably be quite expensive, however if you use a vinyl product it might be okay? I reckon it would probably be much cheaper to buy one, do a comparison on eBay and see how you go!!
  • moffycc
    moffycc
    where are you from dicey ? a bloke  at helensvale GC steve roadrunner seats, all he does is bike seats pretty good ,price wise not sure,done a job for me and can build seats from scratch.
