2009 XL1200C Recommended Tools
  • Blackadder
    Blackadder
    Now the bikes out of warranty most of the minor maintenance work will be done by yours truely. However, I need a reasonable toolkit as there seems to be a real mix of metric and imperial bolts on the bike. As such, what tools would you recommend and where is the best place to buy?
  • fizball
    fizball
    Always buy good quality brand name tools. Look after them and they will last forever and never fail. A good workshop manual will suggest the right tools for your bike. In melbourne I shop at just tools.
    cheers.
  • Rocky2010
    Rocky2010
    Factory Manual is a must, also a good Torque Wrench, one that measures Ft-lbs also one that measures in-lbs is a good starting point.
    Good set of Imperial Allen keys, loctite for certain bolts, the factory manual will tell you what to get.
    Various T-bar spanners metric & imperial are a must also.
    Also you will need to get a good Oil filter removal tool,
    I have used many but found that the original HD on is the best it has a 3/8'' square hole in it so you can attach and extension and ratchet to remove the oil filter as it on the very tight even though you don't do it up much when you install a new oil filter its only about 3/4 turn make sure you put a bit of oil on the rubber gasket before you install the filter.
    Checkout this site if you want to get some tools from the USA, there service is excellent and the goods will be on your doorstep in 4days if the goods are in stock. I have purchased stuff from this site many times now and I have never had any problems with their service.
    Theie website is very easy to navigate, just go to the tools page
    http://www.rockymountainatvmc.com/
    Tools:   http://www.rockymountainatvmc.com/categoryDetail.do?navType=category&navTitle=Tools%2FShop&webCatId=22
  • 883n Harley Convert
    883n Harley Convert
    Blackadder, I posted a 2010 service manual a few weeks back.............find the link and it identifies all tools required to work on ya bike!!
  • Blackadder
    Blackadder
    Cheers all
    Kept wondering if there was one kit for all needs, but that was just niave. Seen quite a few bits on ebay at reasonable prices so will probably start building it up from there. Kicking myself for giving away all my tools when i moved to Aus. There again you live and learn
