Online: tussuck
2011 FLHRC ideas for pipes?
  • jock1
    jock1
  • GRUVY HD
    GRUVY HD
    Muffler • S&S® Power-Tour
    Style • Slash-down - Chrome
    Part No.
    • Power-Tour 106-5981
    I have these and they are great
  • Kustomtown
    Kustomtown
    Hey Gruvy, what about some V&H?
    No problem hearing them....
  • Cowboy
    Cowboy
    Hello Jock1,
    I have had a 96 cube in and FLHRC, and a 103 in an Ultra, both I modified with the V&H PowerDuals.  The reason is that on our local Dyno, the PowerDuals generated the most power on before and after testing, of about 10% HP added....
    However, since then, I have done some more experimenting with the stock pipes as the PowerDuals hang a bit low below the frame and scrape on any hump in the road on a right hand turn...   I also like the look of the stock pipes.   In short, we have now charted almost the same results as the PowerDuals, with the Cat Gut of the stock pipes.  With the catalytic converter out: The stockers have a bit of Venturi effect that extracts the cleaning cylinder with the exhaust stroke of the compression cylinder of the 4 Stroke, the same way as the PowerDuals.   I give some pictures of the how of it, in a Topic about ten down from this one, you might what to have a look at: Surprising Dyno results, for cut out Cat on Tourer.
    It also keeps the clean lines of the stock pipes... You might want to have a look at that Topic, as I like the set up now in performance as well as the V&H Powerduals, and personally I like the looks even better..  Hope it is a help, at least worth a look...
  • groover
    groover
    Personnally can't go past the S&S SPO Ovals
    Thats it
  • aussiesport
    aussiesport
    v&h pro pipe chrome 2-1 ,love the sound of these a little loud but i havent had anyone cut me orf since fitting them :)
