I have bought an 08 HD Deluxe which has 6500kms on it.
Via ebay over the last few months have acquired the following:
1. Set of 21/2 inch Exile drag pipes.
2. Stage 1 efi screamin eagle air filter
3. Power commander III unit.
4. NGK Iridium Spark plugs.
I have a plan. Fit the pipes first, then when it due for a service/tune , fit the pc, air filter and plugs. (think i've loaded a comparitable map)
Ride it to the harley shop for a good tune.
Sounds feasible, or doomed from the start?
Thanks for any feedback.
As they say, there in lies the rub!
Just hope its' all worth it.
Generally Harley dealers don't like after market stuff and don't have Dyno gear.
It's just as easy to cast around here and maybe find a pc111 map that matches your mods, still best to have it dyno'd by an expert though.
Otherwise ditch pc111, as I have done, and go with TTS and tune yourself...
Bt
