Blinkers
  • ozerokky
    ozerokky
    Need a little info. Just bought a 1983 FXRS.  The blinkers stay on while you hold the swich, but as soon as you let it go they stop working?
    Is this how they work?, or should they stay on once the indicator switch is is un thumbed?
    How do yours work?
  • clarkie
    clarkie
    got a 83 fxrs and my indicators stay on until you turn them of,has yours got buttons or rocker style switches.
  • als1200
    als1200
    Is the switch is only a momentary type, need a latching relay to hold on I would think, pm evilshovel for info, he has just done his ride.
  • Burnzi
    Burnzi
    Check out www.badlandsmotorcycleproducts.com they make a unit that will make ur indicators stay on for 11 secs and you can also run LEDs if you want
  • motor_head
    motor_head
    Yep.....thats how they work on the old beast's....unless it is an auto off it's illegal to have indicators that stay on these days, apparently ..........think it might be USA rules, dont know.
  • ozerokky
    ozerokky
    Thanks for all the input. I contacted Badlands, and they put me in touch with Rollies speed shop here on the east coast, and they have a unit for $ 94 incl postage, so thats the way I will go
  • Burnzi
    Burnzi
    Hey Buddy check out Bird at Hdbitz on ebay, he may have the same part or not, might be worth a look if u havnt ordered.
