Battery charging harness/fly lead
  • Harvey Mushman
    Harvey Mushman
    I know there is a topic about this somewhere,but I could be looking for days,so.........
    My bike came with the "Harley Davidson battery harness", which is just a fly lead that allows you to connect a battery charger without pulling the seat,or the battery out of the bike.
    Is the connection on this "Harley Davidson battery harness" a standard sort of a plug fitting ? Or am I going to have it invest in a "Harley Davidson type" charger to be able to take advantage of this fly lead ?
  • shaggz
    shaggz
    do you have a pic of this connection?
    I have 2 different styles of trickle chargers (both non harley davidson) and they both use the exact same plug as each other.
    that is the the same plug as my charger i got it from supercheap  it was called a jr fighter or somthing $ 45 bucks buy memory it comes with clip on terminals aswell just double check the positve  is right  before pluging it in ,hope this helps
  • rider
    rider
    Narva connector,
    Part number 56292BL Weatherproof harness 2Way 16 Amp rating. cable length 270 mm.
    As steamer says, if you upgrade the 3 amp fuse in the circuit, you can use the plug for a power supply when not using it for charging.
    Locate a standard cig lighter plug in a suitable place and plug it in so it can be used for phone charger, GPS, whatever.
    I have run a velcro strip under the electrics side cover and simply attach/detach the double cig lighter plug when and if needed.
    Comes in handy.
  • Harvey Mushman
    Harvey Mushman
  • shaggz
    shaggz
    Exact same plug as both of mine have, I run my plug under the seat up to between the tanks then when I need it I just pull it out from under the leather tank strip and plug it in.
  • Harvey Mushman
    Harvey Mushman
    Cheers Shaggz
  • Sam
    Sam
    Ive got the same plug on my bike, but will be ripping it out soon to replace with the one that came with my trickle charger... Of course it was bloody different!
