Just found out why my bike lost it's drive ,
' The old pully comming off the gear box trick ! ' ..... and to fix it ,.... I've pulled the whole bike down , primary, clutch basket ,even taking out the gear box !!!!!
Something has slipped and the pully won't make mesh with the splines on the out put gear shaft , so the box needed to be open up too .
Good to hear , that they make a better pully for this problem , seams that it was a common fault , ....
so guys , any old harleys 92 ish ...check your nutz !!!! ......or it will do your nutz !!!!
timmey the nut less
On the road again soon then mate??
