fitting a hyper chsrger to efi sporty
  • brucecul
    brucecul
    has anyone fitted a hypercharger to their efi sporty ?. is there a way to make the butterfly work ?
     bruce
  • BAKES
    BAKES
    I had a Pro R hypercharger on me 1200 custom, I just locked it open,
    too much rootin around with the vacuum, not worth the effort.
    but incase you need to know how, from memory if you dig deep on the kuryakyn web site it has the answers.
    mine was for a non efi motor, but it fitted my efi motor no problems.
    and you know its on when your riding, you can hear it sucking in the air. more air more go go, and tuned with TTS
  • 103_Dyna
    103_Dyna
    pretty sure u gotta conect it top the throttle body so the butterflys open when u accelerate.
