sporty cutom advice
  • lastoutlaw
    lastoutlaw
    ive had my son managed to knock my bike over and in this effort bent my bars, dint the tank, knock the indercator off etc
    so i thought in this time of repair i would like to possibly get a bigger tank with the hope that my speedo can be relocated to the tank or the wiring be able to plug straight into the tank speedo and if so which tank will fit properly so i dont have to change the seat etc being an 06 custom sporty (so not the peanut tank)
    im also wanting to raise the bars a little and bring them back a tad so the riding position is a little  better so i thought by changing the tank i could get rid of the speedo that sits on the bars then having a bigger choose of bars
    any ideas, thoughts, help, would be great
  • darkdesign
    darkdesign
    sounds like you're after a quick bob tank, but that's only gonna get you half a gallon over the custom tank. Lotta dicking around for 2 litres. Costly too, unless you can score some second hand stuff cheap. I've used a stock 883xl speedo bracket ( the one with the flat mount to the top riser ) , elongated the holes slightly so it fits on the riser cover bolts instead - only works on a custom with the headlight mounted off the bottom tree. Now i can use whatever riser / bar combo i feel like. Currently got keystones on 4 inch risers, looked great on 1.75's, but quite a stretch with forwards.
    good luck mate.
  • lastoutlaw
    lastoutlaw
    thanks for the input fellas, got me twiddling the thumbs now. gotta fix the tank anyways, a resonable size ding in the bloody thing or just change to spedo mounted tank? new risers and bars or a tweek back on stockys hmmm.......any more ideas out there? once again cheers for any input
  • Sprocket
    Sprocket
    Check out The Handlebar Company. www.thehandlebarcompany.com/  Great range of bars. They are currently custom maikiing me a set of 36 " wide 'new flat and wide bars'. Bloody brilliant price too. $110 NZ ($87 AU) delivered.
  • lastoutlaw
    lastoutlaw
    thanks for the link sprocket
    might get myself a set from them.
    will solve my handle bar issue
  • als1200
    als1200
    Cheers sprocket, going to order some westerns.
  • Sprocket
    Sprocket
    Glad to help guys
  • Sprocket
    Sprocket
    Here are some photos of the bars I bought from the handlebar company.
  • 883n Harley Convert
    883n Harley Convert
    The additional lights look good, never seen them on a sporty...............very cool Sprocket!
