Fat Bob popping
  • McCabe
    McCabe
    I have a MY11 Fat Bob, it is stock with Rush slip ons, its pops alot on trailinfg throtle. I know I need some sort of a tune and am confused by all the options. what will be my cheapest and easiest fix? Thanks in advance for your help
  • McCabe
    McCabe
    Thanks Steamer, what did the SEPST cost?
  • McCabe
    McCabe
    Thanks Obiwan, how much for the XIED and did you fit them you self?
  • McCabe
    McCabe
    Thanks Steamer
  • McCabe
    McCabe
    Thanks Obiwan, to clear thinks up are they just a replacement for the current O2 sensors and where did you get them from?
  • Yositime
    Yositime
    There is no guarantee the Xieds will do anything for popping, they did not help me, a waste of money IMHO. You either need to add back pressure via one of the cheap anti reversion baffles or equivalent. If you want to guarantee you can correct the drivability issue, you need something like the TTS tuning kit. Otherwise a set of ear plugs is cheap.. :)  popping doesn't hurt anything.  The TTS product is a much better tuning tool than the the Harley tuner.
