Online: GGUser260, Wanderer57
Help needed with Dyna S ignition wiring
  • shaggz
    shaggz
    I bought a second hand Dyna S ignition system off here to run twin plug heads on my Shovel. The person I bought it off can't remember how it was wired up and I can't seem to find any wiring instructions that match what I have.
    I got the timing plate, Two coils and a mounting bracket.
    On the timing plate I have two pickups and three wires running from them which are coloured Red, Orange and White.
    There are no part numbers on anything and the coils aren't marked with + or - poles, Part of what I am finding difficult is not knowing if I have two single fire coils which would mean that each coil fires both plugs in one head or if I have two twin fire coils which would mean that each coil fires one plug in each head. The other part of the problem is knowing which of the three wires goes where.
    If there is anyone out there that has any idea what I am on about and knows the answers it would be very much appreciated.
  • The Don
    The Don
     Shaggz,
    ran this set up on my Shovel many moons ago. PM me and I can send you PDF assembly and installation instructions I have.
    Cheers,
    Cris.
  • shaggz
    shaggz
    Thanks Cris, PM sent.
    Forgot to mention that I have downloaded 3 different sets of diagrams from the Dynatek site but they don't match with what I have.
    Cheers Shaggz
  • shaggz
    shaggz
    Looks like I'm not the only one that knows nothin about em
  • The Don
    The Don
  • The Don
    The Don
     Follow up, I just read your original question. You have 2 pick ups, it's a single fire system, white goes to both coils(power), orange to either front or rear coil (1 or 2 towers?) if 2 towers, both leads from that coil go to either front or back cylinder( I pressume you have double plugged heads.) Adjust your timing by ear . Check which one fires front or back(orange or red.) and wire accordingly.
    Hope I'm clear if not get in touch.
    Cheers,
    Cris.
  • shaggz
    shaggz
    Thanks heaps for that Cris, makes sense now. Can't wait to hear the old girl fire up again :)
  • shaggz
    shaggz
    Wow how time flies when ya havin fun. 5 years since I first asked this question and the poor old girl has been sitting in the shed unloved all this time. I just googled this so that I can finally get around to getting this done tomorrow and discovered my old post.
  • spacewolf
    spacewolf
    Time to add some pics of the work then so we can follow!
    It'd be good to see an old shovel getting reloved and restarted.
