throttle stuck on???
  • 666
    666
     hi everyone came back from aride today and throttle was stuck on reving about 2500 any thoughts
  • AJ56
    AJ56
    As a guess is your throttle lock stuck.......
  • timmey
    timmey
    Cables can get a build up of crap on the inside , thus not sliding very well .....wd40 may do the trick , but check if one cable hasn't snapped or is fraying as on my bike it has 2 cables , one pulls and the other pushes.
    Too short of cable can lead to this , as you turn the steering, it pulls on the cable .
  • Rabbit
    Rabbit
    If having tried and failed any of the previous responses, I'm thinkin' either fuel pressure or fuse box. if its the former it may be bleeding fuel past the o- ring, if its the latter, clean up yer fuses and relays with dialectric grease.
  • 666
    666
     thanks everyone for input but cables are fine checked those 1st when it happened wil do the next process and check fuses???? but sounds like iac to me hmmmmmm
